May 12, 2025 9:36 AM UTC
SolidEdge CAD data management problems
Version: Windchill 12.0
Use Case: Hi, We are using SolidEdge since 2018, going through different Windchill-SolidEdge-CADi versions and we are constantly facing problems: - CAD data marked as our of date. - CAD data saved but not marked as modified. - Drawings published with the wrong attributes displayed. These problems are occurring randomly, but they have a huge impact in our activities. I have created several tickets with PTC and Birlasoft, but they have not solved the problem. Is anyone familiar with this kind of problems? Many thanks
Description:
Problems apparently occurring randomly.
  • After the check-in some CAD data is marked out of date, performing refresh or update is not removing the mark. Synchronizing the workspace can work, but often it's asked to check-out some data.
  • Sometimes after the check-in the local modified data is replaced with the commonspace unmodified data.
  • Sometimes the drawings are published with wrong attributes (the actual drawing shows the right one, the published PDF is not).
avillanueva
23-Emerald II
May 12, 2025 3:12 PM UTC
Is it possible to show some screen shots of what you are seeing?
May 14, 2025 3:02 PM UTC
I'll reproduce the issue and then send screenshots and steps performed.
Many thanks
Jul 22, 2025 8:17 AM UTC
Kindly Share details.
Jul 31, 2025 9:59 AM UTC
I'm not able to reproduce all the problems reported above, except for the 1st one:
  • After the check-in, some CAD data is marked out of date; performing refresh or update is not removing the mark. Synchronizing the workspace can work, but often it's asked to check-out some data.
This topic is described in Article - CS223174; the main difference is that performing an update and then a refresh as suggested is not always resolving fixing the out of date.
This is an annoying problem, but it is not dangerous for us as the other ones.
