Mar 17, 2025 8:47 PM UTC
SolidWorks communication with Windchill Workgroup Manager
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.2
When launching SolidWorks 2019, it cannot communicate with the Workgroup Manager. I've tried following the instructions on Article - CS310741 but it does not work. I need help in resolving this issue.
Here are the errors that I faced
Unable to connect to Windchill Workgroup Manager, if more than one instance of the authoring application is running, the new one will run disconnected.
Mar 18, 2025 8:21 AM UTC
Article - "Receiving following error while launching a 3rd party CAD application: "Unable to connect to Windchill Workgroup Manager. If more than one instance of the authoring application is running, new one will run disconnected."": https://www.ptc.com/en/support/article/CS36129
STEVE_V-M4-ParticipantAuthor
Mar 18, 2025 8:31 PM UTC
Thank you VladimirN for your input.  I tried the methods that this article - CS36129 - is suggesting but my SolidWorks still has this problem and is not connecting to Windchill Workgroup Manager.
prerev_kompan
Mar 19, 2025 8:05 AM UTC
Hi Steve
We see that message some times. Usually it's because SolidWorks hasn't closed down properly from the previous session.
If you check Task Manager, you might have 2 or more SolidWorks instances running.
Can be found in Background Processes.
Close all SolidWorks entries.
