May 24, 2024 4:57 PM UTC
Solilworks BOM does not match published PDF
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS16
The SolidWorks drawing BOM does not match published PDF on some objects
SolidWorks part number field linked to Windchill part number field and description linked to Windchill name field.
Here are the errors that I faced
none
    joe_morton
    May 24, 2024 6:05 PM UTC
    I would investigate the publishing settings. Check if publishing is using "as stored" or "latest" configurations. Also check to see if the drawing is being rebuilt prior to publishing. You'll want to configure for whatever is "right" for your business requirements.
    For us (using Creo), we publish drawings always using latest and doing a full regeneration prior to publish. To get the equivalent in a Workspace, you'd have to make sure the workspace is using latest version of every component, and that a full regeneration is done.
    Community Moderator
    Jun 10, 2024 5:47 PM UTC
    Hi @Silvana,
    I wanted to follow up with you on your post to see if your question has been answered.
    If so, please mark the appropriate reply as the Accepted Solution.
    Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
    Anurag
