11-Garnet
Aug 31, 2018 2:47 PM UTC
Solr Index Server 11.0 M030 CPS11
Just updated a test server to PDMLink M030 CPS11 and the separate Solr server to the same release. Now getting a 501 Session Expired error. PTC wants me to add the solr admin I created to the Windchill participants. We normally use the wcadmin for the Solr Effctive UID. Anyone else at the release or has seen this error? And do you add the solr admin to your Windchill participants? Thanks in advance!
borourke11-GarnetAuthor
11-Garnet
Sep 5, 2018 3:57 PM UTC
Follow up to this question. How are you suppose to update the Solr software? When I tried to install the CPS11 Solr software update, the choice to update was greyed out, so I blew the CPS01 Solr away and did a fresh install of the CPS11 Solr.
Apr 15, 2019 1:06 PM UTC
Did you ever get this figured out?  Do you have any pointers if you did?  I am just starting an upgrade test on my test server to this same configuration.  I liked it so much better when Solr was a part of the Windchill install.
