May 6, 2016 7:53 AM UTC
Solr Installation On Existing Windchill PDMLink
Hi All,
I want to install Solr index search on existing Windchill (PDMLink 10.1 M050).
Going to do it for first time, Any detailed procedure and suggestions would be great.
Thanks in advance.
Krishna Chaithanya.
2-Explorer
May 10, 2016 12:13 AM UTC
Hello Krishna,
You need to have atleast one background method server or set wt.queues.executequeues to false.
Regards
Binesh Kumar
Medtronic - MITG
2-Explorer
May 6, 2016 11:42 AM UTC
  1. Download PSI and Solr CDs for 10.1 M050
  2. Ensure that WindchillDS is running.
  3. Run PSI and select Update Existing Installation
  4. Select Install Optional Components > Windchill Index Search
  5. Complete the installation
Regards
Binesh Kumar
Medtronic - MITG
May 6, 2016 12:29 PM UTC
Hi Binesh,
Thanks for your quick response.Will try to install it.
Besides the above steps, I'd also like to know whether they're any post installation steps which need to perform.
Krishna Chaithanya.
2-Explorer
May 6, 2016 1:02 PM UTC
Yes, you have to run bulk index tool. Review the indexing policy from policy administrator.
Run windchill wt.index.BulkIndexTool  and start bulk indexing to index all the existing document. This can slow down the server, so pick a time outside business hours
Regards
Binesh Kumar
Medtronic - MITG
Jul 11, 2016 10:33 AM UTC
Hi there is another way through this,
windchill --javaargs="-Dcom.ptc.net.auth.user=<username> -Dcom.ptc.net.auth.password=<password>" wt.index.BulkIndexTool
  • Doesn’t work in all cases, but can help with some command lines. The “ “s are needed for Windows. Unix may work better with single quotes ‘ ‘ s
This should start bulk index tool UI wherein you can select whichever option you need.
Jul 11, 2016 1:09 PM UTC
Hi Ganesh,
Noted and will try the same. Thanks for the response
Krishna Chaitanya
