11-Garnet
Aug 29, 2022 7:46 PM UTC
Solr with 12.0 PDMLink
Recently did an upgrade of PDMLink 11.1 to 12.0 on a test sever, and we wanted to re-index all of our Solr entries. Running Solr on a standalone server, and deleted the existing entries to start the re-index. All of the entries are failing. Double checked the connections and made sure the Solr admin and password match on the 2 servers. i know you now longer have to create the cores, but was wondering if I should blow them away and do a manual build. Just inquiring to see if anyone else has experienced this. Many thanks in advance!
22-Sapphire I
Aug 30, 2022 4:08 AM UTC
Did you also set up the solrserver.properties file?
CS353251
borourke11-GarnetAuthor
11-Garnet
Aug 31, 2022 6:41 PM UTC
Thanks for the info Mike. This was one of the first solutions I tried.
avillanueva
23-Emerald II
Aug 31, 2022 6:48 PM UTC
Any firewall blocks between or on the servers?
