Aug 15, 2016 1:19 PM UTC
Something odd when running the compare tool for WTpart structure to CAD assy structure
Regarding all components of associated CAD assy, all my components are associated and built fine, but when running the compare CAD structure to wtpart structure tool or vice versa, nothing red comes up, but I have situations where the wtpart does not show up in the compare tool, but CAD components are visible.
One way I have figured out how to fixed that......... I have to delete that component out of CAD assy and reassemble, then run Build Association again or check in CAD assy, then the compare tool shows correctly.
What is your experience with that, why does that have to be done?
Do you have another method to remedy that problem?
