Nov 29, 2022 7:21 AM UTC
SQL server is consumed more memory
I am using Windchill 11.0 and Datecode M030
SQL server is consumed more memory for BLOBS and logs
I am unable to open the windchill application
May 2, 2023 7:56 PM UTC
You will need to handle logs first. If transaction log is full:
https://www.ptc.com/en/support/article/CS261702
https://www.ptc.com/en/support/article/CS41551
Once you have Windchill application running you may need to revault the BLOBS:
https://www.ptc.com/en/support/article/CS120635
18-Opal
Jun 7, 2023 1:29 PM UTC
Hello Rajesh.Dubba,
I'm Charles from PTC Technical Support in Europe: Was the information provided helpful somehow? Or may I suggest you open a new case for this question?
KR,
Charles.
