SQL to Fix Filename=Name=Number?
Does anybody know of a way fix any objects that may not have Filename= Name=Number?
We have some that are not correct and would like to fix them.
I was hoping it would be a simple piece of SQL.
Joe
Joe,
What's the logic to fix them. In other words, if Filename, Name and Number arenot equalwhich value will you use to populate the other two. Below I assumed CADName
I'd do it this way:
Create an Info*Engine task that contanins two webjects
1.Query-Objects webject queryfor all EPMDocumentsMasters. You need to edit this query to limit the number of masters returned
2.Query-Objects webject queryfor type = wt.epm.EPMDocumentsMaster where name!=CADName|number!=CADName
3. Change-Identity webject to do the rename/renumber
The code is below. Past it in a file named fixNames.xml
Put fixNames.xml into WT_HOME\tasks\ext\tools
Login to Windchill test system and edit the URL:
http://<
WARNING: Limit this query do not use it as it as it will try to return all EPMDocumentMasters.
<ie:webject name="Query-Objects" type="OBJ">
<ie:param name="INSTANCE" data="&lt;%=instance%">"/>
<ie:param name="TYPE" data="WCTYPE|wt.epm.EPMDocumentMaster"/">
<ie:param name="WHERE" data="number=*"/">
<ie:param name="ATTRIBUTE" data="*"/">
<ie:param name="GROUP_OUT" data="output"/"></ie:webject>
Find those that do not match
<ie:param name="WHERE" data="number=${output[*]number[*]}"/">
<ie:param name="WHERE" data="CADName!=${output[*]number[*]}"/">
<ie:param name="WHERE_CASE_SENSITIVITY" data="FALSE"/">
<ie:param name="GROUP_OUT" data="output2"/">
</ie:webject>
Rename/Renumber those that do not match
<ie:webject name="Change-Identity" type="OBJ">
<ie:param name="OBJECT_REF" data="${output2[*]obid[*]}"/">
<ie:param name="FIELD" data="name=${output2[*]CADName[*]}"/">
<ie:param name="FIELD" data="number=${output2[*]CADName[*]}"/">
</ie:webject>
in SQL
Before you do this beware that SQL updates simply edit the value. There is no check to see if that number is already in the dB.
Make sure the target numbers don't exist before doing the update. Otherwise you'll have two Masters with the same number which is obviously not good.
this query will return the target numbers that already exist. You MUST exclude these numbers from the update below.
select documentnumber from EPMDocumentMaster where documentnumber in (select upper(CADName) from EPMDocumentMaster where DocumentNumber!=upper(CADName));
this update statement will do a mass update. DO NOT use this unless the query above returns nothing.
update EPMDcumentMaster set Name=CADName where upper(Name)!=upper(CADName);
update EPMDcumentMaster set DocumentNumber=upper(CADName) where DocumentNumber!=upper(CADName);
Hope this helps,
David
In Reply to Joe Barnes:
Joe
colmacpro1-VisitorAuthor
I followed your instructions but when I connected to the URL after logging in I just got a blank page and nothing changed in the database. Your code did remind me of a SELECT statement I had for something elsething which led me to the UPDATE SQL statement below.
>sqlplus
SET NAME=upper(CADNAME), DOCUMENTNUMBER=upper(CADNAME)
upper(NAME)<>upper(CADNAME) OR upper(DOCUMENTNUMBER)<>upper(CADNAME);
The UPDATE statement seems to have worked, but right now I need to test it a little more before trying it on the production system.
Joe
20-Turquoise
September 10, 2012
> >sqlplus
> *UPDATE EPMDOCUMENTMASTER*
> *SET NAME=upper(CADNAME), DOCUMENTNUMBER=upper(CADNAME) *
> *WHERE *
> *upper(NAME)<>upper(CADNAME) OR upper(DOCUMENTNUMBER)<>upper(CADNAME);*
You also need a commit:
commit;
> Joe
> -----End Original Message-----
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
Does anybody see anything wrong with doing this?
When I talked to PTC Tech support they told me they did not have or support anything. They then referred me to the PTC GS team for a possible tool or utility..
Joe
Joe,
Making updates directly in the database is generally not recommended. In this case, the EPMDocument identity information is also stored in the EPMDocumentMasterKey table and might get out of sync if the EPMDOcumentMaster table is updated through a SQL statement
Instead, the preferred approach for updating the EPMDocument name and number is by using the following API
IdentityHelper.service.changeIdentity
Ravi
