Dobi
Oct 3, 2023 3:10 PM UTC
Standard profile turns off change notice
I made a recent change where I needed to turn off visibility/write access to specific attributes on WTParts. So profiles seemed the way to go.
I made a profile that made the desired attributes be read only and added users to it.
Now, none of those users have the "New/Create Change Notice" option in Actions.
Both the standard profile i made and the license profiles of the users have "Create Change Notices" and "Start Change Notice Executions" checked, though.
If I take the users out, the "New" with it's submenu returns. Why?
Dobi
DobiAnswer
Oct 11, 2023 9:31 PM UTC
It turns out that the solution to this was to "turn it off and turn it back on".
In other words, my profile was correctly set up. I had to go into to it and turn off the "create change notices" options and then turn them back on and everything came back to life.
Dobi
Dobi17-PeridotAuthor
Oct 3, 2023 3:28 PM UTC
To make matters more confusing, applying the standard OOTB PDB profile seems to restore it despite my profile having identical settings.
HelesicPetr
Oct 4, 2023 6:05 AM UTC
Hi @Dobi
It seams that your profile does not have same settings
PetrH
Dobi
Oct 4, 2023 2:19 PM UTC
You'd think... I went through and lined them up so that they are identical across both but the behavior is still the same. One works and the other doesn't.
