Feb 19, 2025 3:34 PM UTC
state based filters on reference documents
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.0.2
How to have reference documents into a package depending on the state of the document? I would like to add a wtpart associated with some reference documents of a particular state into a package. Filters in structure tab of the part or in the package does not get applied for reference documents.
https://www.ptc.com/en/support/article/CS372457?oskarSession=32d5ea0f-662b-488b-99c1-1abcdf77fc71&source=support_assistant
Catalina
Community Manager
Feb 26, 2025 1:05 PM UTC
Hi @PM_8995700
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
Aug 5, 2025 6:07 PM UTC
I'm experiencing the same issue, and would like to know if anyone else has found a solution.
HelesicPetr
Aug 6, 2025 8:05 AM UTC
Hi @BD_11091511
As the article says it works to product spec.
You have two options.
Create an Idea to implement such function - you would wait for it almost a decade 😄 or
You can just develop own function that can do what you need.
You need create own customization maybe own wizard where you could use own collection logic to collect all objects based on your criteria.
PetrH
