Feb 9, 2018 1:34 AM UTC
Status Code: 500 Error occured
We using Windchill PDMLink 11.0 M030 CPS6,
and when search from the simple search item in the upper right of Windchill, it get an error like following.
Request URI: /Windchill/wtcore/jsp/com/ptc/windchill/search/Search.jsp
Query String: portlet=component
Status Code: 500
Exception: wt.util.WTRuntimeException: java.lang.ClassNotFoundException: ${domain}.Note; nested exception is: java.lang.ClassNotFoundException: ${domain}.Note
Does anyone know the solution?
hsano-2Answer
Feb 13, 2018 5:24 AM UTC
This problem solved by PTC technical support.
Follow is same problem and solution.
<https://www.ptc.com/ja/support/article?n=CS101558#_ga=2.19494257.811665916.1518485624-1378123833.1508143170>
hsano-21-VisitorAuthorAnswer
