STEP file publishing with revision information.
Hello.
 Has anybody been successful in including the revision number when publishing STEP files? I've tried to read the documentation about it but haven't found anything. Either in the filename or in the step file attributes would be fine.
Thanks.
22-Sapphire I
We've had this in production for several years.  Took quite a lot to decipher PTC's instructions on how to set up. Please see attached procedure - hopefully will be helpful.
22-Sapphire I
You can find instructions in PTC support article
https://www.ptc.com/en/support/article/CS216668
