Feb 1, 2024 5:56 AM UTC
Stp file not genereated,User is not able to see see Stp file when we publish manually it is showing
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS20
Stp file not genereated,User is not able to see see Stp file when we publish manually it is showing but automatically it is not generated
    HelesicPetr
    Feb 1, 2024 8:19 AM UTC
    Hi @PM_10272594
    I guess that you use Publish Rules. So you need to set that publish rules are used during the check in.
    If manual publish wizard show you the option, then I would check if property is set..
    publish.usesPublishRules has to contain PROE option.
    xconfmanager -s publish.usesPublishRules="ARBORTEXT PROE" -t codebase\WEB-INF\conf\wvs.properties -p
    Check the property in the wvs.properties
    PetrH
