Apr 18, 2024 12:47 PM UTC
Strings are limited to 500 characters
Windchill strings are limited to 500 characters.  A locked constraint.  How do you increase the string length to 750 or given another option for a larger String when defining a new attribute?
avillanueva
23-Emerald II
Apr 18, 2024 1:06 PM UTC
https://www.ptc.com/en/support/article/CS24652?source=search
There is a link to the customizer's guide.
avillanueva
23-Emerald II
Apr 25, 2024 5:27 PM UTC
Not sure if you are referring to Enumerated Types (i.e. create a new String2 type), or creating Large Objects (LOBs).
HelesicPetr
Apr 26, 2024 7:51 AM UTC
Hi @CraigFinney
If you go through the guide that @avillanueva has provided, you will find a way how to increase the character limit up to 2000 chars for IBA string attributes.
Knowledge base
PetrH
