May 20, 2019 12:54 PM UTC
Structure Views in "Compare to Part Structure"
when you use the function "Compare to Part Structure" for a wtpart, you can "Manage Structure Views" for both frames. Wouldn't it be more useful, if you could manage both structure views at once. I don't see a Use Case, where you want to compare two part structures, but with different views.
Patrick
