Apr 9, 2015 2:58 PM UTC
Substring function for "folder.id" in OIR
Hi All,
I'm trying to get a substring of the "folder.id" attribute of a WTPart. I'm using the below OIR code and I'm getting a failure with the IndexOf algorithm. Does anyone have an example where you use IndexOf as a parameter to Substring? Please don't send the one from the Help, I've already seen it.
<attributevalues objtype="wt.part.WTPart">
<attrvalue id="lifeCycle.id" algorithm="com.ptc.core.foundation.lifecycle.server.impl.LifeCycleTemplateAttributeAlgorithm">
<value algorithm="wt.rule.algorithm.BooleanBranch">
<value algorithm="wt.rule.algorithm.StringEqualsTest">
<value algorithm="wt.rule.algorithm.Substring">
<attr id="folder.id"/">
<value algorithm="wt.rule.algorithm.IndexOf"> <-- This algorithm is causing the OIR to fail. If I hard code to an integer then it works.
<arg>Manufacturing</arg>
<arg>0</arg>
</value>
<value algorithm="wt.rule.algorithm.LastIndexOf"> <-- This algorithm is causing the OIR to fail. If I hard code to an integer then it works.
<attr id="folder"/">
</value>
</value>
</value>
<arg>Steelcase Eng B Life Cycle</arg>
<arg>Steelcase Eng Life Cycle</arg>
</value>
</attrvalue>
</attributevalues>
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image001.jpg@01D072B4.2CC608C0]
Apr 9, 2015 3:08 PM UTC
How about insert some java code into that webject example. Of course all that steelcase stuff in there may be causing the failure 🙂
Jim Van Dragt
PLM Architect
Information Technology
hermanmiller.com
Apr 9, 2015 3:09 PM UTC
This is not a webject Jim. It's OIR xml file.
[cid:image002.jpg@01D072B5.976C0430]
Apr 9, 2015 4:27 PM UTC
There are problems where index of etc works only in certain scopes where
folder.id is null and at other points you do see the value. I just
customize my own algorithm. Fairly basic code you almost never have to
worry about in an upgrade.
On Apr 9, 2015 10:59 AM, "Williams, Patrick" <->
wrote:
> Hi All,
> I’m trying to get a substring of the “folder.id” attribute of a WTPart.
> I’m using the below OIR code and I’m getting a failure with the IndexOf
> parameter to Substring? Please don’t send the one from the Help, I’ve
> already seen it.
> <attrvalue id="lifeCycle.id"&lt;br"/>> algorithm="com.ptc.core.foundation.lifecycle.server.impl.LifeCycleTemplateAttributeAlgorithm">
> <value<br/>> algorithm="wt.rule.algorithm.BooleanBranch">
> <value<br/>> algorithm="wt.rule.algorithm.StringEqualsTest">
> <value<br/>> algorithm="wt.rule.algorithm.Substring">
> <value algorithm="wt.rule.algorithm.IndexOf"> ß This
> works.
> <arg>0</arg>
> </value>
> <value algorithm="wt.rule.algorithm.LastIndexOf"> ß This algorithm
> </value>
> </value>
> </value>
> Cycle</arg>
> Cycle</arg>
> </value>
> </attrvalue>
> </attributevalues>
> *Patrick Williams* | Engineering Systems | c: 616.947.2110
> [image: sc_inc_black_sig_1_alt]
