Jan 12, 2024 11:02 PM UTC
Sync Time Delay for New File Adds?
I just added a couple of dozen files (~100k bytes each) to Windchill using the "drag and drop to Windows File Explorer" method.
I can see these newly-added files in the File Explorer window that is enhanced by the Windchill add-in.
However, I cannot see the newly-added files in the Windchill's "Navigator" HTML browser window.  Is there a significant sync delay (hours?) between these?
Refreshing the Navigator browser window doesn't make any difference. The files are still not visible after 2 hours.  My internet connection is solid.
jimolsonAnswer
Jan 15, 2024 6:18 PM UTC
Thanks, avillanueva.  Our A/P person should be sending you $ for the help you're providing me.
The problem turns out to be more subtle than syncing.  All of the eCAD files I stored into WC last week were tagged with new file types created by my company's WC administrator.  For example, he created a SCH file type for my electrical schematics and BOM file type for my bills of materials.
I asked him to create the new file types because WC has a bad habit of stripping Window's file extension .xxx from files rostered in the Windows File Explorer.  Instead the add-in enhanced Windows File Explorer has a column called |File Type| that effectively restores the missing file extents.
Apparently when you create new file types in WC the default setting for their viewability in Windchill Navigator is "no visibility".  I mistakenly interpreted this "no visibility" as a lack of syncing between Navigator and Windows File Explorer.  Admin guy is presently working in his admin menus to restore the visibility of these new file types in Navigator.
avillanueva
23-Emerald II
Jan 12, 2024 11:58 PM UTC
Were they check in? See you checked out work table on your home page. No there should not be any delay.
ANTONIO VILLANUEVA
ASSOC. DIRECTOR, PLM AND CM
AVILLANUEVA@ARKA.ORG
203-948-9556 CELL
203-797-5682 OFFICE
DANBURY MISSION TECHNOLOGIES
100 WOOSTER HEIGHTS ROAD
DANBURY, CT 06810
ARKA.org
CONFIDENTIALITY WARNING: This message may contain proprietary and/or privileged information of ARKA and its affiliated companies. If you are not the intended recipient, 1) do not disclose, copy, distribute or use this message or its contents, 2) advise the sender by return email and 3) delete all copies (including all attachments) from your computer. Your cooperation is greatly appreciated.
P Please consider your environmental responsibility before printing this e-mail.
jimolson12-AmethystAuthorAnswer
