Mar 7, 2016 12:11 PM UTC
Table with Text box in windchill
Is there any way we can create the Textbox in the component builder and a search button
Please help if any body know this
Mar 9, 2016 7:43 PM UTC
Hi Ankit,
As mentioned earlier, the second link should be helpful.
Also, you may want to try following to get started. It's not a complete example though.
1. Create a jsp with a simple form, you can also do this by creating attribute panel
<input type="text" size="25px" id="EnterNumber" name="EnterNumber" value="">
<input type="text" size="25px" id="EnterName" name="EnterName" value="">
  <input type="button"  id="SubmitButtonID" name="SubmitButtonID" value="Search" onClick="submitFunction();">
<div id="mvcTable">
  <mvc:tableContainer compId="<<YOUR COMPONENT ID>>" height="600" />
  </div>
2. Include the JS
function submitFunction() {
  var number = document.getElementById('EnterNumber').value;
  var name = document.getElementById('EnterName').value;
  var params = {
  number : number,
  //reload the table builder
  PTC.jca.table.Utils.reload('<<YOUR COMPONENT ID>>',params,true);
3. In your builder you should be able to get the parameters as shown below
public Object buildComponentData(ComponentConfig  config, ComponentParams params) throws Exception {
  String PartNumber= (String) params.getParameter("number");
  String PartName = (String) params.getParameter("name");
Bhushan
Mar 7, 2016 1:45 PM UTC
Are you creating a Wizard? Can you check following links on your server to see if that helps.
http://<<HOSTNAME>>/Windchill/app/#netmarkets/jsp/componentCatalog/wizardComponent.jsp
http://<<HOSTNAME>>/Windchill/app/#ptc1/comp/carambola.testClients.search
Bhushan
adev1-VisitorAuthor
Mar 8, 2016 2:38 AM UTC
Hello Bhushan,
No I am not creating a Wizard I like the functionality like search where I can input some values and as per that I will get the result
Ankit
Hi Ankit,
<div id="mvcTable">
  </div>
2. Include the JS
  var params = {
  number : number,
Bhushan
