8-Gravel
Aug 26, 2025 8:47 AM UTC
Taking report to know 'view' only access user's last login time
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.0
I need to take a report from windchill to see user's who has only 'view' access, their last login time to windchill. Is there way a to extract this information?
    joe_morton
    Aug 26, 2025 2:37 PM UTC
    Probably the easiest way to get some data is to go to Site -> License Management, then go to the Report tab. You can run a report on the period you specify. It gives some data that might get you close to what you're looking for.
    8-Gravel
    Aug 27, 2025 12:53 PM UTC
    Thanks. But I could not find License management option under site in windchill. I have database access. Do you know any table where I could pull this information: View access user's last login time.
    avillanueva
    23-Emerald II
    Aug 27, 2025 1:09 PM UTC
    Combined with the reports provided by @Marco_Tosin , you can export the PTC View and Print Only License group. You can do this from the partipants administrator. Select on the group and export to CSV. The two Excel extracts can be joined by the username to give you what you want.
    avillanueva
    23-Emerald II
    Aug 26, 2025 2:50 PM UTC
    What is your ultimate goal? Is this a one time extract or something you need to run many times? There should be a report of active users and their last logins. If you do not have that, let me know since I can extract QML for that. Now to know if they are a View and Print iser, only have view access, you just need to extract that group. Should be able to cross merge those extracts in Excel to get what you need. Note that this does not say anything about the user's access over time. A user could have been removed from the View and Print group or recently added. All you can tell is that they are currently in that group now. Let me know if you need further help.
    8-Gravel
    Aug 27, 2025 12:55 PM UTC
    Thanks for the response. My goal is to extract the list of users who has only view access and their last login time. This is a one time report I need. I have database access. Do you know any table where I could pull this information: View access user's last login time.
