Sep 26, 2023 9:03 AM UTC
Task Assigned
Hi Everyone,
I have 100 pdf, i want to assign all this into individual user's. So i decided to go with Project Management, but i didn't know how i can assign on one shot.
1. Assign the pdf to designer.
2. Once designer is done and deliver that.
3. If there any rework how that same designer can work / if any emergency i can swap into new designer.
Thanks in Advance
Amir
Fadel
FadelAnswer
23-Emerald II
Sep 26, 2023 12:11 PM UTC
you can add as many task as you wish and each task may have a different assigned user and affected pdf
Buiꓘa
Fadel
23-Emerald II
Sep 26, 2023 9:32 AM UTC
at your place,I would go for change management
when the pdf are approved /reviewed they even may get released for any possible use downstream if needed
Buiꓘa
Sep 26, 2023 10:09 AM UTC
Thank you for the replay and video Mr. Fadel,
But here can we assign individual users to receive the task, Here single user we can assign more pdf. Right
Amir
HelesicPetr
Sep 26, 2023 10:48 AM UTC
Hi @Amirtharaj_K
Yes, you can crate one task per user and add there the document.
PetrH
