Apr 8, 2020 3:30 PM UTC
Task list showing Submit tasks
When a file is checked into Windchill 11.0 m030, the wcadmin account ends up with a Submit task in the Task list.
I can only Accept, Decline or Reassign these tasks. I want to delete them!
How do I delete them?
How do I prevent new ones from appearing?
What do I need to modify in my Windchill setup to eliminate them from being generated?
Swapnil4Answer
Apr 9, 2020 2:53 PM UTC
Seems like you are using Advance lifecycle for Objects and forgot to remove the workflow process for sates . can you check lifecycle template  and removed if workflow phase and gate process from lifecycle state .
for existing running and unwanted such running process you can terminate  running process from workflow process administration.
Hope this helps
Swapnil41-VisitorAnswer
Hope this helps
BenLoosli23-Emerald IIIAuthor
Apr 10, 2020 5:51 AM UTC
I was able to clear all but 1 submit process. I will look further into removing it.
In my lifecycle phases, they all have the Submit workflow and the gates have a Review workflow.
All I need to do is uncheck the box at the end to disable the workflows for each state?
Apr 11, 2020 8:05 AM UTC
yes you can clear the workflow process  (Submit and Review) for each state.if you don't need those workflow processes
also, you can set your lifecycle to Basic if you dont need any workflow.
hope it helps
