Jan 20, 2016 5:43 AM UTC
Team template of object "XXX.drw, -.1" does not exist in the target context. What is the solution for this error?
Hi All,
Could u please let me know what's the solution for the below error message?
Thanks in advance.
PSH
Jan 20, 2016 8:46 AM UTC
Can you provide details when are you getting this error, while creating object or moving object?
By looking at drawing version it seems like you are getting error while creating/check in new drawing. Check if team template given in OIR is existing in Windchill. If you are getting error while moving object from one context to another then look at below solution
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS25841&
Hope it helps
shreyas
