"template.templated" Attribute Value
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.13 What dictates the value of template.templated which is often used to dictate the life cycle an object is set to in OOTB OIRs?
TDTAnswer
18-Opal
Hi ​@BF_13811900,
The template.templated attribute indicates whether the Change Notice object was created as a template or as an actual Change Notice.
When you create a Change Notice template, it is technically created as a Change Notice object, but the template.templated attribute is set to true. Therefore, Change Notice templates use the Basic lifecycle instead of the Change Notice lifecycle.
When you create an actual Change Notice using a Change Notice template, the template.templated` attribute is set to false.
The OOTB behavior is designed this way so that the Change Notice lifecycle is not applied to a Change Notice object when it is created as a template.
If the object was created in the templates area then template.templated is 1 otherwise 0
Thanks but I’m still a bit unclear. The xml script seen below is used in the OIR for an OOTB change notice object. The way I interpret this is that the lifecycle given to a new change notice object is dependent upon the value template.templated is set to. Every change notice I create seems to get set to the ‘Change Notice Life Cycle’. I’m aware there is a “Templates” option available under certain container types in the GUI but I can’t see how it is possible to create the object in this area. How can a change notice object be created in such a way that it results in being set to the “Basic” life cycle?
<AttributeValues objType="wt.change2.WTChangeOrder2">
<!--  set the folder  -->
<AttrValue id="folder.id" algorithm="com.ptc.core.foundation.folder.server.impl.FolderPathAttributeAlgorithm">
<Arg>/Default</Arg>
</AttrValue>
<!--  set the lifecycle  -->
<AttrValue id="lifeCycle.id" algorithm="com.ptc.core.foundation.lifecycle.server.impl.LifeCycleTemplateAttributeAlgorithm">
<!--  if (template.templated)  -->
<Value algorithm="wt.rule.algorithm.BooleanBranch">
<!--  test this value  -->
<Attr id="template.templated"/>
<!--  if true  -->
<Arg>Basic</Arg>
<!--  if false  -->
<Arg>Change Notice Life Cycle</Arg>
</Value>
</AttrValue>
TDT18-OpalAnswer
18-Opal
Hi ​@BF_13811900,
Thank you very much! That clears things up.
