3-Newcomer
Jun 20, 2023 1:42 AM UTC
The advanced search feature has issues with the latest version of search
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
Search" -> "Latest Version Search" has been set to "Yes" in the preferences, but in the search results, the old version will be searched out; after analysis, the search for parts whose "Specification" attribute is "A1" is the largest and latest If the attribute of version E is not "A1", but the "specification" attribute of version D is "A1", then version D will be displayed in the search results. The desired effect is: if the property of the largest and latest version is not "A1", the part does not need to be displayed in the search results.
Translated text from Simplified Chinese to English using google translate. By Community Moderation team.
Subject:  高级搜索功能对最新版搜索有问题
Body: 首选项中已经设置了“搜索”-》“最新版搜索”为“是”,但是搜索结果中,会将旧版本搜索出来;经过分析,搜索“规格”属性为“A1"的部件,最大最新版E版的该属性不是”A1",但是D版的“规格”属性为“A1",则搜索结果中显示D版本。期望的效果是:如果最大最新版该属性不是”A1“,则搜索结果中不需要显示该部件。
jbailey
18-Opal
Jun 20, 2023 1:01 PM UTC
When you set the preference, did you set it as your user? at org? site?
If you just set it at org/site, you have to delete child instances, otherwise the user(s) will still have the default preference set.
