7-Bedrock
Feb 2, 2026 11:50 PM UTC
The CAD Document associated from the Upstream Branch doesn't transform to the Downstream Branch
I am using Windchill MPMLink Release 13.0 and Datecode with CPS 13.0.2.2
The associated CAD Document (owner) is not moving to the Downstream Branch.
Fadel
FadelAnswer
23-Emerald II
Feb 16, 2026 4:42 PM UTC
New downstream  part are another properties
com.ptc.windchill.mpml.copyOver.mapsb.newPart.xxxx some are for wtpart attriburtes and association others for partmaster and other for usageattributes
Buiꓘa
18-Opal
Feb 3, 2026 3:09 AM UTC
Hi @KERanck,
Please refer to the following article to enable the functionality
https://www.ptc.com/en/support/article/CS218496?source=search
18-Opal
Feb 3, 2026 2:32 PM UTC
Hello KERanck,
Is the kb article CS218496 shared helpful somehow ?
KR,
Charles.
KERanck7-BedrockAuthor
7-Bedrock
Feb 5, 2026 8:00 PM UTC
No, this is not really that helpful. It doesn't answer my question. I want to know if the CAD Document is supposed to transform from the upstream view to the downstream view. Is it just a preference setting or does something else need to be done?
TomU
Feb 5, 2026 8:38 PM UTC
Based on the linked article, the CAD is not carried to the downstream view when using 'new downstream branch'.  Changing the settings listed in the article will turn this on.
