May 22, 2026 1:48 PM UTC
The conditional checks if the PBO is drawing; if so, it advances; if not, it terminates.
I need to create a conditional statement that checks if the PBO is drawing; if so, it advances; if not, it terminates. However, as a new Windchill administrator, I'm having trouble and can't find an article that can help me.
20-Turquoise
May 22, 2026 2:29 PM UTC
You can use something like the following:
If using this in a workflow you will need need to fully qualify the classes. eg
EPMDocument will change to wt.epm.EPMDocument.
if (primaryBusinessObject instanceof EPMDocument) {
EPMDocument doc = (EPMDocument) primaryBusinessObject;
if (doc.getDocType().toString().equals("CADDRAWING")) {
// doc is a drawing
} else {
// doc is a not a drawing
May 22, 2026 3:03 PM UTC
I'll test the solution and let you know if it works. Do you recommend any articles or courses from PTC where I can learn more about this?
20-Turquoise
May 22, 2026 4:01 PM UTC
There are typically multiple PTC articles that would be of help but today I am getting:
Sorry. Article 229067 was not found. Here are some options:
when attempting to search for articles.
Felco Solutions offers Windchill API training:
https://www.felcosolutions.com/training
avillanueva
23-Emerald II
May 26, 2026 12:48 PM UTC
Where is the workflow running? Is it on the Change Task or Change Notice? If CN, must account for multiple change tasks.
Community Moderator
Jun 1, 2026 4:34 PM UTC
Hi ​@CZ_12009435,
Anurag
