Aug 28, 2024 3:32 PM UTC
the handle is invalid Windchill
I have a problem with a shortcut on the server machine that should execute the following command
C:\ptc\Windchill_13.0\Windchill\bin\windchill.exe -w “C:\ptc\Windchill_13.0\Windchill” --java=“C:\Program Files\Amazon Corretto\jdk17.0.12_7\bin\java.exe” shell and it shows
HelesicPetr
Sep 9, 2024 6:10 AM UTC
Hello @MS_Santos
I would recommend to use different place for java JDK.
The C:\Program Files\ is very strict area, and I have experience similar issues if the JDK is placed there
Does not matter that you run it as an Administrator.
So install/move the JDK to different place then C:\Program Files\...
PetrH
jbailey
18-Opal
Aug 28, 2024 7:41 PM UTC
Is Java still in that location?
MS_Santos15-MoonstoneAuthor
Aug 29, 2024 10:27 AM UTC
When you say this location, is it the Windchill server? If so, yes
jbailey
18-Opal
Aug 29, 2024 11:19 AM UTC
Just verifying that the file path to java is the same as what you have in your command
Sep 6, 2024 1:41 PM UTC
It may be a conflict on java itself, if you have multiple versions installed, try uninstalling all java, restarting the computer and then installing only one java.
HelesicPetr
Hello @MS_Santos
PetrH
Community Moderator
Sep 17, 2024 7:04 PM UTC
Hi @MS_Santos,
Anurag
