Jun 18, 2024 1:53 PM UTC
The object with the following key was deleted or inaccessible: "wt.part.WTPart:21931276672"
Version: Windchill 12.0
Use Case: The object with the following key was deleted or inaccessible: "wt.part.WTPart:21931276672"
Description:
i am facing an error, "The object with the following key was deleted or inaccessible: "wt.part.WTPart:21931276672""
this is when i am revising a Non-Cad document which is linked as describe by document to a WTpart.
can somebody help?
Sandy
Jun 19, 2024 8:05 AM UTC
Article - "Check-in part fails with "The object with the following key was deleted or inaccessible: "wt.epm.EPMDocument:12345" in Windchill PDMLink": https://www.ptc.com/en/support/article/CS131389
olivierlp
Community Manager
Jun 26, 2024 1:35 PM UTC
Hi @Sandy7 ,
I wanted to see if @VladimirN 's reply helped. If so, please mark it as the Accepted Solution. It will help other members who may have the same question.
Olivier
