May 20, 2025 8:21 AM UTC
the QueueLock table is often locked in the system
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.1.2
Nowadays, the QueueLock table is often locked in the system, but its status is inactive. I want to know how this deadlock is caused and how to optimize it in the future to avoid this situation from happening。
HelesicPetr
May 20, 2025 8:29 AM UTC
Hi @YP_10630130
It is usually cased by performance issue and too much queue entries.
Always you should investigate the performance of the server.
There can be some improvement by indexes or you can try to run a WindchillConfigAssistant tool
ant -f utilities/wca/WindchillConfigAssistant.xml configureCacheManagerSizes -Dpropagate=true
PetrH
