Gerhard@SD
6-Contributor
The revision ID value may not contain the series delimiter character: "."
Has anybody an idea what's behind this change in Windchill 13.0? https://www.ptc.com/en/support/article/CS423384
We have been told that the dot was never really supported but not checked till WT13.0.
We and our suppliers are used to have a x.y rev. system for decades!
Anybody already changed the system? Side effects?
Thank you for your valued answers! 🙂
Fadel
23-Emerald II
I'm not sure if I have understood this correctly , But I think you talk about the multilevel versioning like A.A.1 .
Prior to 13.0 we could have systems form WC9 with legacy contexts having multilevel versioinng ,while new context use single level , there was also a tool to convert to sungle level .
Starting 13.0 multilevel is prohibited and all data need to be converted to single level before upgrade
Buiꓘa
avillanueva
23-Emerald II
I think you are right on @Fadel . 13 is the first version that removes multi-level versioning. I think having a custom series with dots would be confusing for any parsers that PTC had. I would open a TS ticket but start planning on altering your version series. Did you just upgrade or are you testing upgrades?
Gerhard@SD
6-Contributor
Hi, more a switch over from another world to WT. Perhaps interesting what other WT using companies have done to end multi-level versioning. Or are we the only customer with this topic? Thank you for your advices!
