Jul 11, 2024 8:34 AM UTC
the server is currently unavailable
I am using Windchill PDMLink Release N/A and Datecode with CPS N/A
Windchill server does not work with Creo PTC 5
Here are the errors that I faced
    jbailey
    18-Opal
    Jul 11, 2024 10:28 AM UTC
    What version / build of Windchill?
    Jul 15, 2024 7:46 AM UTC
    Windchil PDM essential on Creo 5.
    thanks for reply.
    Jul 15, 2024 3:39 PM UTC
    There is a matrix for Windchill versions and the related Creo versions that it will work with.
    We need both the Windchill version and the Creo version to be able to give you an answer.
    Since Creo 5 is out of date and no longer supported, I would guess that Windchill support stopped at Windchill 10.2, maybe WIndchill11.0.
    olivierlp
    Community Manager
    Jul 11, 2024 12:23 PM UTC
    Hello @SA_10556661 .
    Adding to what @jbailey asked, I recommend you tak a look at How to Ask a Good Question - PTC Community. Thank you for your participation.
    Olivier
    HelesicPetr
    Jul 17, 2024 8:04 AM UTC
    Hi @SA_10556661
    If the page shows "The service unavailable" information, it is usually that the server is not started or restart is in progress.
    You should contact your admin to check why the windchill service is not up.
    PetrH
