Jul 14, 2023 10:23 AM UTC
the vault sync when we changing the SyncMode SYSTEM to SITE getting error
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
While performing the vault sync when we changing the SyncMode SYSTEM to SITE through jconsole it's getting below error
Problem invoking modeSwitchToSite: java.rmi.UnmarshalException: Error unmarshaling return: nested exception is:
java.lang.ClassNotFoundException: wt.util.WTException (no security manager. RMI class loader disabled)
Here are the errors that I faced
    HelesicPetr
    Jul 14, 2023 10:42 AM UTC
    Hi @YK_10474275
    I use PTC Knowledge Base Search and I've got a result
    CS198791 RMI class loader disabled
    In your specific case I guess that you just do not use correct java library from Windchill.
    "wt.util.WTException" is a class from Windchill and this class can not be missing
    This class is located in a folder > WTHOME/codebase/wt/util/
    check your application if it has access to the class
    PetrH
