11-Garnet
June 26, 2024
The way Forward
  • June 26, 2024
  • 2 replies
  • 638 views
Version: Windchill 12.1
Use Case: Good day I am new to Windchill and I would like to find out some information regarding Add-ons etc to our windchill. We have the need to configure in Windchill, Product breakdown structures and CAD data. We need to create a Part structure and manage it. Below is what we currently have installed. Release 12.1.2.5 Products Installed Creo View Windchill 2.6.1 REST services Windchill projectlink 12.1.2.1 creo view adapters Windchill 12.1.2.5 service pack Windchill pdmlink 12.1.2.0 windchill 12.1.2.1 info*engine windchill 12.1.2.0 services windchill 12.1.2.0 common base I have been told that we need Model Based Systems Engineering Module as well as aspects of Codebeamer. Can someone Please guide me with more info on this requirement. Regards
Description:
No Problems just looking for info on system functionality.
avillanueva
23-Emerald I
June 26, 2024
Youtube is great for getting the overview you need but you want to stick to more recent videos, something no older than 2 years. Based on what you have, you can support the basics of Part structure and CAD management however it depends more on the licenses you own and their allocation. If you want to get into library part management, classification and supplier management, look at PartsLink and SupplyLink add-ons. If you need to integrate with an ERP system to push BOMS and Parts downstream, there is the ESI modules, either indirect or direct for added cost (TIBCO) and those would be ERP system specific.
It also sounds like based on MBSE and Codebeamer, you are looking at software and source code management? I know very little about that. You might be able to get a series of web demos from your local PTC rep.
Community Moderator
July 8, 2024
Hello @Markh74
It looks like you have a response from a community member. If it helped  to answer your question please mark the reply as the Accepted Solution.
Community Moderation Team.
