Jun 23, 2015 1:38 PM UTC
The WPA Material loader should be able to use substances that have duplicate CAS numbers in WPA.
In WPA, substances with duplicate CAS Numbers are allowed so long as they have different substance
names or IMDS ID's.  However, we cannot load these substances onto a material using the material
loader because the material loader gives an error if it finds multiple substances with the given
CAS number in WPA.
What I'm proposing is that the material loader should have a field for the user to enter the IMDS ID,
and the logic of the loader should be changed in order to use a combination of CAS Number, Substance
Name, and IMDS ID to identify the substance rather than just using CAS Number.  Basically, the
loader should identify substances the same way WPA does.
Aug 24, 2015 7:59 AM UTC
hi Zachary,
can you describe when you want to distinguish between different forms of the same substance, i.e. the same CAS-number? I have similar needs but have not considered using the IMDS ID to do it. It should perhaps be another functionality built in to the standard.
