7-Bedrock
November 6, 2024
There is a problem with the visualization position in the structure tab.
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.1.1
The data of the CAD document from SolidWorks is normal, and the data after checking in Windchill is also normal. There is a problem with the visualization position in the structure tab. Is there any good solution?
Email: 17674619511@136.com
Translated the text from Simplified Chinese to English using Google translate
Body - CAD文档从SolidWorks程序中的数据正常,检入windchill之后的数据也是正常的,在结构标签页中的可视化的位置出现问题,有什么好的解决办法吗
邮箱:17674619511@136.com
-By Community Moderation Team
Community Moderator
November 12, 2024
Hi @WC_9256664,
Thank you for your question.
Your post has not yet received any response. Please feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
And I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team.
7-Bedrock
April 28, 2025
please hae a look to Article - CS348405 - the orientation needs to be aligned with the ISO view --> same as it is in SOLIDWORKS
