There is no way to bulk delete latest at a selected Release state, i.e. ("Release Change")
If a user creates a "new-revision" of a whole assembly by mistake and creates many new release change iterations, there is no way to delete this latest iteration, in Intralink you could locate and delete "selected" or "all versions" allowing you to delete the latest at a selected release state. In PDMLink searching for and deleting with the X delete will remove the entire object versions. Attempting to delete the latest top assembly and all components causes the system to timeout and freeze at the conflict screen.
