8-Gravel
May 8, 2024 11:48 AM UTC
thousand separation point
Version: Windchill 12.0
Use Case: This is the Attribute "building year" and should be the data type: "java.lang.Long"
Description:
Where can i remove the thousand separation point in Windchill 12.0.2.0?
Thank you
avillanueva
23-Emerald II
May 8, 2024 12:26 PM UTC
Do you have screen shots? Building year, is that one of your custom attributes? I am not familiar with that. Are you looking for a way for an attribute value for example 432,410,040 to be displayed without comma separators? Like 432410040? How is attribute defined? Please show setup for it.
8-Gravel
May 8, 2024 1:05 PM UTC
uvex_windchill_0-1715173378150.pnguvex_windchill_1-1715173408296.pnguvex_windchill_2-1715173453688.png
left you see the problem. it should be 2023 and not 2.023
avillanueva
23-Emerald II
May 8, 2024 3:46 PM UTC
Ahh, I see. Perhaps this should have been a String and not a long (Integer).
Community Moderator
May 27, 2024 7:59 PM UTC
Hi @uvex_windchill,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
