Apr 24, 2023 6:38 PM UTC
Tibco HawkRandomAccessFile.dll starts with problems
I'm getting some log errors when start Tibco's services.
The log files says that can't find dependent libraries, but don´t show the ones, at least the names.
2023 Apr 18 17:42:39:521 GMT -03:00 HawkAgent.JACVMQASESI02 Error [Application] HWKXXX-000010 E:\ptc\esi_12.0\tibco\hawk\6.2\bin\HawkRandomAccessFile.dll: Can't find dependent libraries
2023 Apr 18 17:42:39:522 GMT -03:00 HawkAgent.JACVMQASESI02 Error [Application] HWKXXX-000018 In LFMicroAgent exception from scan thread: java.lang.UnsatisfiedLinkError: E:\ptc\esi_12.0\tibco\hawk\6.2\bin\HawkRandomAccessFile.dll: Can't find dependent libraries
at java.base/java.lang.ClassLoader$NativeLibrary.load0(Native Method)
at java.base/java.lang.ClassLoader$NativeLibrary.load(ClassLoader.java:2430)
at java.base/java.lang.ClassLoader$NativeLibrary.loadLibrary(ClassLoader.java:2487)
at java.base/java.lang.ClassLoader.loadLibrary0(ClassLoader.java:2684)
at java.base/java.lang.ClassLoader.loadLibrary(ClassLoader.java:2649)
at java.base/java.lang.Runtime.loadLibrary0(Runtime.java:827)
at java.base/java.lang.System.loadLibrary(System.java:1871)
at COM.TIBCO.hawk.agent.logfilema.HawkRandomAccessFile.<clinit>(HawkRandomAccessFile.java:71)
at COM.TIBCO.hawk.microagent.logfilema.LFStream.<init>(LFStream.java:41)
at COM.TIBCO.hawk.microagent.logfilema.LFMonitor.initializeStream(LFMonitor.java:110)
at COM.TIBCO.hawk.microagent.logfilema.LFMonitor.initialize(LFMonitor.java:104)
at COM.TIBCO.hawk.microagent.logfilema.LFMonitor.getData(LFMonitor.java:156)
at COM.TIBCO.hawk.microagent.logfilema.LFMicroAgent$ScanThread.run(LFMicroAgent.java:524)
This cause a problems on start or stop services, that can´t be automatized and necessary someone solved manually.
Plus, there a lot of services stayed locked on memory, and need to be killed manually.
P.S.: Apparently doesn't chash the working, but fill the server´s memory with stucked aplications repeteadly.
Apr 26, 2023 9:40 PM UTC
I found it a solution!
Problem solved with this post from Tibco Support page
https://support.tibco.com/s/article/Failed-to-start-hma-in-windows-server-2016-and-2019
From about 20 days ago (!)
Thank you all!
Apr 25, 2023 1:14 PM UTC
Found a similar issue - "Unable to start TIBCO Administrator process with error: Startup error: java.lang.UnsatisfiedLinkError: <TIBCO home>\tibjre64\xx\bin\awt.dll: Can't find dependent libraries in Windchill Enterprise Systems Integration 12.0": https://www.ptc.com/en/support/article/CS369011
Apr 25, 2023 1:30 PM UTC
Thank you Vladimir, we'll try this suggestion.
Apr 25, 2023 5:35 PM UTC
Have you checked what hawk.log file is saying?
Are there out of memory errors, such as: 'java.lang.OutOfMemoryError: Java heap space'?
Apr 25, 2023 6:00 PM UTC
Yes, i'm checked and couldn't found more information. There's not OutOfMemory or some like this, i make a search on hawk.log, hawk1... until the last one hawk5.log.
Pasting a litle part of the hawk.log text:
2023 Apr 25 01:24:40:133 GMT -03:00 HawkAgent.JACVMQASESI02 Info [Application] HWKXXX-000015 In LFMicroAgent: ScanThread started...
2023 Apr 25 01:24:50:135 GMT -03:00 HawkAgent.JACVMQASESI02 Error [Application] HWKXXX-000010 Could not initialize class COM.TIBCO.hawk.agent.logfilema.HawkRandomAccessFile
2023 Apr 25 01:24:50:135 GMT -03:00 HawkAgent.JACVMQASESI02 Error [Application] HWKXXX-000018 In LFMicroAgent exception from scan thread: java.lang.NoClassDefFoundError: Could not initialize class COM.TIBCO.hawk.agent.logfilema.HawkRandomAccessFile
Thank you.
Apr 26, 2023 12:21 PM UTC
You can run  HawkAgent in debug mode by setting parameter -log_level in hawkagent.cfg to 8. See if it gives more information.
FabioValente12-AmethystAuthorAnswer
Thank you all!
