11-Garnet
May 27, 2024 8:30 AM UTC
Time and Date report
Version: Windchill 12.1
Use Case: Good day. I am new to Windchill and I need help with a report that can give me the time and date of when the state changes for a document. For example when I create a new document it is a revision A.1 in a state of "in work". After a few days it is changed to a revision B.1 and changed to a state of "under review". I need a report that can give me the time and dates of all these event changes.
Description:
MarcoTosin
May 27, 2024 9:05 AM UTC
The only way to track the date change in reference to an object state change is to use workflow tasks.
Here you can read what is changed in the DB with each date change.
What is the usage of database UPDATESTAMPA2 and MODIFYSTAMPA2 columns in Windchill
Which database table stores "Start Date" and "Date Completed/End Date" of all workflow task/activity of "Routing/Process History" table in Windchill PDMLink
And this is a report to record the dates of each task in the workflow
How to report completed tasks and date/time with QueryBuilder in Windchill PDMLink
Marco
Emeritus
May 30, 2024 10:09 AM UTC
Hello @Markh74,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
joe_morton
Jul 2, 2024 4:16 PM UTC
If you just want to report when the state changed, independent of a workflow, you can use the query builder to make something like this:
This will let you get a report that corresponds to the "Life Cycle History" table for the document. It's helpful to compare the query results with this table. You may need to customize your view to see it:
I usually include this criteria, to only get timestamps when the object entered the state:
There's a lot of help articles on using Query Builder. You'll need to add more criteria to get just the results you're interested in.
