Jun 1, 2015 7:27 PM UTC
Tip: ModelCHECK DIR_REPORT path for Windows environment
Hello all,
When configuring ModelCHECK and setting DIR_REPORT in config_init.mc the path is interpreted as Windows if you specify a static path, for example:
DIR_REPORT c:\myusershomebaseetc\subfolder\mc_reports
But let's say you want the report to live in a subfolder based on the windchill username?  You might want to do this if you don't use the windows provided %USERPROFILES% which is c:\users\<username>\ in most cases.
Here's what I found works on Windows 7 professional:
DIR_REPORT $homedrive/home/$USERNAME/mc_reports
(Note the forward slashes, this is opposite to Windows convention of '\' backslashes for paths.)
If you do want to use %USERPROFILES% you would use this:
DIR_REPORT %USERPROFILE/mc_reports
These below options do NOT work in my testing:
DIR_REPORT $homedrive\home\$USERNAME/mc_reports
DIR_REPORT $homedrive\home\$USERNAME\mc_reports
DIR_REPORT c: \home\$USERNAME/mc_reports
DIR_REPORT c:\home\$USERNAME\mc_reports
All results in Creo Parametric 2 M120 defaulting to the folder where Creo was started, as documented in the Creo help system.
Related PTC articles: TPI 31240, CS116772.
Jun 1, 2015 8:59 PM UTC
Hello Everyone,
Note if you turn on option: MC_METRICS it will write that as a separate file.  You specify the location of that file with: DIR_METRICS setting in config_init.mc  It does not follow DIR_REPORT.
- Jim
Jun 17, 2015 10:08 PM UTC
Hello all,
Another follow up on this.  It seems any variable set in your Creo startup script that contains valid path information can be used to set the DIR_REPORT path in config_init.mcc
I now have our set to:
DIR_REPORT $homedrive/home/$windchill_username/mc_reports
For info on HOMEDRIVE see: https://support.microsoft.com/en-us/kb/101507 ‌this seems to apply to Win 7 in our environment.
/home is just where the previous admin here parked all user local files.
$windchill_username is a set variable I set in our site's Creo startup script.  Because I do NOT use setlocal in that script, it appears to be available to the Creo sessions started from that script.  Note the script can be run from a desktop shortcut, you don't have to start it from a command line.
Hope this is useful to someone!
Jun 7, 2017 2:17 PM UTC
I tried using the %USERPROFILE% variable in different formats, but kept getting an error about write access, which makes little sense to me since I have full access on the local directory I created to store the reports. I verified this by using a static path, which worked. Eventually, I found that using $HOMEPATH works all the same.
