Mar 19, 2024 8:53 PM UTC
Unable to check into Windchill java.langNullPointerException
I am using Windchill PDM Essentials Release 10.2 and Datecode with CPS M010
Upon uploading or checking in I the "upload failed" the following message in event manager java.lang.nullpointerexception. I have cleared cache and workspace, restarted Windchill, rebooted server.
Here are the errors that I faced
java.lang.NullPointerException
Fadel
23-Emerald II
Mar 20, 2024 9:42 AM UTC
can you share the errors in the MS logs, we can't really tell much only with the NPE
Buiꓘa
bthompson4-ParticipantAuthor
Mar 20, 2024 12:13 PM UTC
where would I find MS logs?
avillanueva
23-Emerald II
Mar 20, 2024 12:25 PM UTC
If you are the site admin, Site - Utilities - Server Status - Monitoring Tools
if you have access to the server, WT_HOME/logs folder.
Mar 29, 2024 2:16 PM UTC
Thanks to those that tried to help.  The issue was a little deeper with my server.  After that was straighten out, then a Java issue but once that was resolved then took much help from Tristar to get me up and going.
avillanueva
23-Emerald II
Mar 29, 2024 2:44 PM UTC
If possible to summarize, that would be helpful for closing out this thread.
