Mar 16, 2023 11:44 AM UTC
Unable to connect to repository http://andrei.gmxhome.de/eclipse/content.xml when following CS63697
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.9
bhushan.dAnswer
Apr 21, 2023 3:04 AM UTC
Hi @Gucio ,
Please note that now the plugin used for File Synchronization comes bundled with Eclipse.
 I see you were able to resolve this issue by downloading Eclipse Plugin from Marketplace.
Also same is documented in CS343591 - "ant -f bin/tools.xml eclipse_project.help" Command that describes Eclipse IDE installation is outdated pointing to invalid FileSync address in Windchill PLM
I will make this comment as resolution and close the thread.
Bhushan
Mar 16, 2023 1:22 PM UTC
Does the Eclipse log show what repository you cannot connect to? Do you perhaps have firewall rules preventing the connections, just a guess?
Gucio16-PearlAuthor
Mar 27, 2023 7:15 AM UTC
It was not problem with firewall. in the meantime PTC has created CS378621 article - installation form Eclipse Marketplace works fine.
bhushan.d17-PeridotAnswer
Hi @Gucio ,
Bhushan
