Dec 1, 2023 12:32 PM UTC
unable to delete ,menufecturing WTpart
i am trying to delete E.1 version of menufecturing WTpart part which i revised by mistake but while deleting it is showing an error "Referential integrity violations occurred for this operation:
Object "Release Activity - com.ptc.windchill.esi.txn.ReleaseActivity:136xxxxxxxx" references the object "Part - Wxxxxxxxx, xxxxxxxx,D.1 (Manufacturing)" that was removed from the system."
could you please help.
Br,
Sandeep C.
avillanueva
23-Emerald II
Dec 1, 2023 1:57 PM UTC
Depending on your level on integration with ERP, these tables are important for allowing Windchill to keep track of what its sent over before. However, if your goal is to delete, then this article is safe to follow. Make sure the revision in your ERP system is good as well.
avillanueva
23-Emerald II
Dec 1, 2023 12:46 PM UTC
You are blocked since it was published via your ESI integration. Check the Enterprise Systems transaction manager for that part and see if its listed. It is possible to remove those transactions but will allow the version to be deleted.
Sandy712-AmethystAuthor
Dec 1, 2023 12:51 PM UTC
Could you please guide me where to check ESI trasection manager for the part?
avillanueva
23-Emerald II
Dec 1, 2023 12:52 PM UTC
Its on the Site - utilities page. You need to be the site admin to see that. Your system is integrated with an ERP system right? Your admins need to be engaged to remove this.
Fadel
23-Emerald II
Dec 1, 2023 1:29 PM UTC
@Sandy7 follow steps in  https://www.ptc.com/en/support/article/CS282808
Buiꓘa
avillanueva
23-Emerald II
Dec 1, 2023 2:54 PM UTC
thank you guys. the article is really helpful.
Br,
Sandeep C.
