May 22, 2015 4:47 AM UTC
Unable to get Newly Created lifecycle states for particular type of documents
Hi All,
Good Day To You..
I've created  new document type and assigned it to basic lifecycle which I've created newly.
But, after this, I've created  document of newly created type and checked it's lifecycle states. But, could not find my newly crated states but instead of that, default Basic Lifecycle states (OOTB) are appearing.
How can I assign my new lifecycle states to my document types other than OOTB states ?
Kindly request you to please suggest me.
Thanks in advance
Regards--
Krishna Chaithanya
May 22, 2015 6:48 AM UTC
Hi All,
I could get the solution.
Actually, I've not properly edited OIR of particular document. But, now edited it and re-assigned new document to this life cycle.
So, it's working fine.
8-Gravel
May 22, 2015 1:17 PM UTC
Krishna,
You need to set the appropriate Document OIR to assign your new lifecycle to your object.  The OIR contains a section for setting the LC, under the tag lifecycle.id.
Modify the Arg string to call your desired LC.
<Arg>My New Lifecycle</Arg>.
Russ
And why your follow-up post from last night failed to display until I submitted this response, who knows?
