Sep 25, 2023 3:23 PM UTC
Unable to launch PSI for Windchill 13.0 on Windows 10
just like in the title I am trying to install test server on VM and I am not able to launch PSI wizard for Windchill 13.0 and 12.1. When I run setup.vbs there is progress bar with some configuring info and then window is closed.
I have java:
java version "17.0.8" 2023-07-18 LTS
Java(TM) SE Runtime Environment (build 17.0.8+9-LTS-211)
Java HotSpot(TM) 64-Bit Server VM (build 17.0.8+9-LTS-211, mixed mode, sharing)
 and java in environments:
Thanks in advance.
TomU
TomUAnswer
Sep 25, 2023 6:50 PM UTC
Have you seen this notification on the PTC homepage?
It leads to this article: https://www.ptc.com/en/support/article/CS398580
Try rolling back to an earlier build of Java.
Sep 25, 2023 4:21 PM UTC
Is Windchill 13.0 supported on Windows 10? Normally Windchill is installed on servers, like Windows Server 2019.
Are you running the PSI as administrator, Run As Administrator?
I tried to find a matrices for Windchill 13 compatibility but did not see one.
MattPat14-AlexandriteAuthor
Sep 25, 2023 4:27 PM UTC
Yes, I tried to launch it also thru powershell with administrative priviliges but same issue. It's closing after the startup progress bar will hit 100%.
Same errors occurs on Windchill 12.1 PSI.
TomU
TomU23-Emerald IVAnswer
avillanueva
23-Emerald II
Sep 25, 2023 6:57 PM UTC
We might have a winner. Good pick up.
