Jan 29, 2024 8:52 AM UTC
Unable to load Library Container template and Quality Container Template
@HelesicPetr
Im loading using below template xml files
TAG-0 file kept at location <loadXmlFiles\>(which got after exporting as Template)
<NmLoader>
<!--                    General Quality Document container Template    -->
<csvCreateContainerTemplate handler="wt.inf.template.LoadContainerTemplate.createContainerTemplate">
    <csvname><?loc-begin key="QMS_CONTAINER_TEMPLATE_NAME" maxlen="150"?>Quality Container Template<?loc-end ?></csvname>
    <csvenabled>true</csvenabled>
    <csvxmlPath>QualityDocumentTemplate_Tag-0<?loc-begin key="LANG_FILE_EXT" pseudotrans="_ja"?><?loc-end ?>.xml</csvxmlPath>
    <csvcontainerClassName>com.ptc.QMS</csvcontainerClassName>
    <csvparentContainerPath>/</csvparentContainerPath>
    <csvdescription><?loc-begin key="QMS_CONTAINER_TEMPLATE_DESC"?> Quality Document container Template<?loc-end ?></csvdescription>
</csvCreateContainerTemplate>
</NmLoader>
For Library container same as above but
<csvcontainerClassName>wt.inf.library.WTLibrary</csvcontainerClassName>
jlecozAnswer
Jan 29, 2024 9:34 AM UTC
Sample load file set  I built to load library container templates (between NMLoader tag) for an older version of Windchill:
PRJ1_CONT_TEMP.xml (file used to load multiple container templates)
<?xml version="1.0"?>
<!DOCTYPE NmLoader SYSTEM "standardX05.dtd">
<NmLoader><csvCreateContainerTemplate handler="wt.inf.template.LoadContainerTemplate.createContainerTemplate" >
<csvname>Customerxx_General</csvname>
<csvxmlPath>..\..\setup\LoadFiles\TEMPLATES\PRJ1_ORG_DR_TEMPLATE.xml</csvxmlPath>
<csvcontainerClassName>wt.inf.container.OrgContainer</csvcontainerClassName>
<csvdescription>Customerxx organization template</csvdescription>
</NmLoader>
PRJ1_ORG_DR_TEMPLATE.xml (used to load specific setup for my template library)
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE LibraryConfig SYSTEM "standardX10.dtd">
<LibraryConfig>
<projectMember><Role roleType="VIEWER4"></Role></projectMember>
<projectMember><Role roleType="DESIGNER"></Role></projectMember>
<projectMember><Role roleType="VIEWER2"></Role></projectMember>
<projectMember><Role roleType="EXTERNALDESIGNERS"></Role></projectMember>
<projectMember><Role roleType="VIEWER3"></Role></projectMember>
<projectMember><Role roleType="PRODUCT MANAGER"></Role></projectMember>
<projectMember><Role roleType="VIEWER1"></Role></projectMember>
</LibraryConfig>
load command
windchill wt.load.LoadFromFile -d PRJ1_CONT_TEMP.xml -u xxxx-p yyyyyy
Hope this helps
jlecoz15-MoonstoneAnswer
</NmLoader>
<LibraryConfig>
</LibraryConfig>
load command
Hope this helps
Jan 29, 2024 12:19 PM UTC
Thanks @jlecoz  Its helpful
Now Im trying to Load Quality containers I have loaded a template on org level named as "Quality Container Template"
but its saying "Context could not be created because the template with the name "Quality Container Template" could not be found."
while loading Quality containers
Jan 29, 2024 12:43 PM UTC
I think there is an issue with loading subtypes on Org-Level. Not sure, but if you can upload the template to site, it could work.
