Unable to Load Users to Group with LoadFromFile
10.1 M040
I am trying to load EnterpriseLDAP users to an existing Org level group.  The group DN is "cn=steelcase external,cn=public,o=steelcase
inc.,ou=people,cn=administrativeldap,cn=windchill_9.1,o=steelcase inc." and am using the command UserGroup.  However I keep getting the below error.  How can I get UserGroup to search higher up the tree in the local LDAP?
2015-09-22 08:20:18,284 INFO  [RMI TCP
Connection(342)-10.80.96.61] wt.system.out wcadmin - Error detected in
createUserGroup <ABURGESS/Steelcase External>
2015-09-22 08:20:18,285 ERROR [RMI TCP
Connection(342)-10.80.96.61] wt.org.LoadPrincipal wcadmin -
  1. wt.util.WTException: No principal was found for the dn:
    cn=Steelcase
    External,ou=people,cn=AdministrativeLdap,cn=Windchill_9.1,o=Steelcase Inc.
at wt.org.LoadPrincipal.validatePrincipalFoundByDN(LoadPrincipal.java:1254)
at wt.org.LoadPrincipal.addMemberByDN(LoadPrincipal.java:1245)
LoriSoodAnswer
23-Emerald II
September 29, 2015
Hi Patrick,
I worked on C12755759 with Mike Genovese today and I think we may have figured out the problem in this case. The full MS log you provided for the case yielded some clues.
Your MS log shows the following:
2015-09-22 07:02:43,500 INFO  [RMI TCP Connection(165)-10.80.96.61] wt.system.out  - Getting container path= ''
2015-09-22 07:02:43,500 INFO  [RMI TCP Connection(165)-10.80.96.61] wt.system.out  - ERROR: Container path not set for this file, contact the author of the loadFile
2015-09-22 07:02:43,500 INFO  [RMI TCP Connection(165)-10.80.96.61] wt.system.out  - FIX THE LOAD FILE SET!
2015-09-22 07:02:43,500 INFO  [RMI TCP Connection(165)-10.80.96.61] wt.system.out  - Using the Windchill PDM container. If it doesn't exist will use the exchange instead.
2015-09-22 07:02:43,500 INFO  [RMI TCP Connection(165)-10.80.96.61] wt.system.out  - Could not find Windchill PDM container, using exchange instead
2015-09-22 07:02:43,501 INFO  [RMI TCP Connection(165)-10.80.96.61] wt.system.out wcadmin - Using container with path= '/'
The lines in red indicate that the file is getting loaded into the Site level context. Since the Steelcase External group is an org-level group it can't find the group and is erroring out. You need to specify a CONT_PATH value pointing to the organization where the group exists in the LoadFromFile command.
We tested this out in-house with a group that is also defined in the AdministrativeLdap under the cn=Public... area and got similar results to what you were seeing when CONT_PATH was not specified. It worked if CONT_PATH pointed to the organization where the group existed:
We used the following XML:
<?xml version="1.0" ?><!DOCTYPE NmLoader SYSTEM "standardX20.dtd">
<NmLoader>
<csvUserGroup handler="wt.load.LoadUser.createUserGroup" >
    <csvuser></csvuser>
    <csvgroupName>AAAA</csvgroupName>
    <csvgroupNameDirectoryService></csvgroupNameDirectoryService>
    <csvuserName>ptcuser</csvuserName>
    <csvuserNameDirectoryService></csvuserNameDirectoryService>
    <csvDirectoryService></csvDirectoryService>
</csvUserGroup>
</NmLoader>
Also tried this with the same result:
<NmLoader>
    <csvuser></csvuser>
    <csvgroupNameDirectoryService>com.ptcts.Ldap</csvgroupNameDirectoryService>
    <csvuserName>wcadmin</csvuserName>
</csvUserGroup>
</NmLoader>
We then used the following command to successfully load the file:
windchill wt.load.LoadFromFile -d Add_Group_Principals.xml -u wcadmin -p wcadmin -CONT_PATH \"/wt.inf.container.OrgContainer=PTC\"
I think if you update your loadFromFile command to specify the CONT_PATH to point to your organization then the load will be successful.
Could you add the xml or the csv?
UserGroupSteelcase
  External
ABURGESS
sorry this is the one I tried.
UserGroup,,Steelcase External,com.steelcase.Ldap,ABURGESS,com.steelcase.EnterpriseLdap,
