8-Gravel
May 2, 2024
Unable to loate Bill of materials table for EPM document master items in database of windchill table
I am using Windchill PDMLink Release 11.2 and Datecode with CPS 11.2.0.3
Unable to loate Bill of materials table for EPM document master items in database of windchill tables
    HelesicPetr
    Hi @Vignesh_AJ_77
    I understand, so check the article I've provided, you will understand the connections.
    then you can check the database tables .
    You could see some similar names with the information provided in the article.
    Especially following tables in the database EPMDocument table and also EPMDocumentMaster, EPMDocumentMemberLink tables are interesting.
    PetrH
    HelesicPetr
    Hello @Vignesh_AJ_77
    The BOM of EPM Document is in the detail page in the structure Tab.
    btw use the support knowledge base search
    CS131357
    PetrH
    8-Gravel
    May 2, 2024
    Hi @HelesicPetr ,
    Thanks for the response. But I need to locate this BOM info in the database tables of windchill. Not in the UI.
    HelesicPetr
    Hi @Vignesh_AJ_77
    PetrH
    Community Moderator
    May 8, 2024
    Hello @Vignesh_AJ_77,
    It looks like you have some responses from a community member. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
    Community Moderation Team.
