3-Newcomer
Oct 25, 2023 12:20 PM UTC
Unable to login into the windchill license issue
I am using Windchill PDMLink Release 11.2 and Datecode with CPS 11.2.1.0
After Rehost, Windchill is starting but showing license issue. But in master server we are able to access the windchill.
error : wt.session.SessionUsers$PreLoginException: wt.licenseusage.licensing.LicensingException: Access is denied. You are not a registered Windchill user.
note: in slave server iis is configured
Here are the errors that I faced
avillanueva
23-Emerald II
Oct 25, 2023 1:28 PM UTC
Can you explain a bit more about what changed during rehost? Did you make a clone of system? Is this a monolithic setup?  From what you posted, sounds more like the user that authenticated is not created in Windchill. Did you pull a new license file for the rehosted system (ID likely changed)?
3-Newcomer
Oct 27, 2023 6:34 AM UTC
We have first converted the cluster to monolithic ( changed made in site and wt.properties)
Then ran the rehost utility.
Then reverted back the process mono to cluster.
In slave we are using iis as apchae.
After that only we are getting this issue
Rocket_Max
Oct 26, 2023 8:25 AM UTC
Hi @AC_9015419
Something wrong in JNDI adapter
3-Newcomer
How can we know that
Rocket_Max
Oct 27, 2023 7:01 AM UTC
Hi @AC_9015419
Enable logger
  • wt.licenseusage
  • wt.adapter
Oct 27, 2023 7:45 AM UTC
You can check below article for Windchill 11.2:
https://www.ptc.com/en/support/article/CS390877?source=search
May 29, 2026 12:41 AM UTC
I am playing with code to add user to license group
as an admin I am in basic license group
code allows me to add anybody to that basic license group because I am in that group
but because I am not in Premium license group, I cant add users to premium group
im trying to find right import, but all didnt go to wc 13 or ???
May 29, 2026 12:45 AM UTC
same as advanced license group, not in there, cant add there
unless I add my self to all 3 license groups &/or many other license groups
I can add users to alll non-license groups though
does not like
import wt.org.OrganizationServicesHelper;
import wt.org.LicenseGroup;
import wt.org.LicenseGroupMember;
not these either
import wt.licenseusage.LicenseGroup;
import wt.licenseusage.LicenseGroupHelper;
